Getrag 240 question
On mine (an E30 version) I replaced the input and output shaft seals and the shift selector shaft seal.
The fluid came out clean and it shifts into all gears. That doesn't tell you a lot but I too, have a couple of spares in case.
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
  • 1 year later...
So are you asking if its the same bolt pattern as an M10?
Measure centerline distance between the 2 bolt holes on the flat section, has to be 12cm to fit an M10
The 2 ears on top indicate it fits an M42/ M40 and wont fit an M10.
Measure it to be sure
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
Yes measure the center line of the top holes should be approximately 4 3/4 inches to fit a m10, but what happened to the bottom of the bell housing?
George S Patton
M40 is the same architecture as M42, just has a single cam.
Also to answer a question previously mentioned in the thread, VIN tags were added to body panels, bumper reinforcements, cylinder heads and transmissions for the 1987 model year in the US and that lasted through the end of E36 production (actually the Z3, since that was the last E36).
1973 2002 tii
1974 2002 turbo
