72 2002 running rought
Need some help from the 2002 gurus.
My recently purchased 72 was running a bit rough and due for a tune up. I did a full maintenance job
(fluids/wires/plugs/points/condenser) etc etc
Anyways now It won't start and when it does it runs like it's misfiring kind of like timings out. But timing is dead on. I think it's a weak spark. I tested the ignition stuff per the serviced manual and everything seems ok.
Thoughts?
Also check the point gap.  If it's closed up tighter than specs you'll get a spark, but it'll be weak and will cause misfiring.
Recently ran into this problem.
