Sudden grinding / binding noise
burndog
After leaving Brisbane I noticed a loud grinding / binding noise coming from left rear wheel area.
It does not occur in reverse, just rolling forward both in neutral and under power.
Any thoughts? Brake pad / caliper, CV joint? I'll year into it on Thursday, but I cannot imagine what it might be.
Burndog
* Loose brake shoe resulting from a broken brake spring
* e-brake cable came adrift from its bracket and either the cable end or the bracket is dragging along the drum as it turns
* inboard axle bolts have come loose (they do that)
* any number of other similar problems.  Suspect it'll be pretty obvious when you start crawling around under the car....
Let us know whatcha find.
Could you have bashed the backing plate so that it now interferes with the drum?
If it only makes a noise in one direction, it sounds like something caught between the shoe and the drum at the top where the friction material stops.
rtheriaque wrote:
Should have clarified, they are the VW MK1 disc brake conversions on rear. Though it could still be the ebrake spring / cable, something in-between pad and rotor or the axle boot... Will check everything and report back.
Thanks!
