Water to manual choke conversion question
scatman75
Hey all, converting from the stock water choke to a manual choke this week and looking for the best solution for the existing water lines, should I run a bypass or block it off, any help(and pictures) would be appreciated
Sent from my SM-G950U using Tapatalk
I have seen both, if you are using your original intake manifold the easiest would be to run a bypass hose of the same diameter between the connection on the intake manifold and the connection on the block that feeds the water choke.  If you are swapping the intake manifold for a Cannon or Lynx, just plug the block connection.
Mark92131
1970 BMW 1600 (Nevada)
