76' custom fog light question
FLEMINGO
I am currently working on a 1976 02' and im making a custom fog light mount for the front of the car. The lights will mount on the bumper mount (the big shocks sticking out of the front) via a slanted cross beam welded to the shocks. I however want to shorten the shocks (because they stick out like crazy). Ive read that you can just drill them and collapse them but I dont really want to spray the fluid everywhere, I was wondering if there was a more humane way to do this?
Easy way is to drill them and collapse them, despite the mess.  Some people fabricate shorter solid mounts and I believe I have seen prefabricated kits available on-line.  I think Bill Holmes at Bavarian Rennsport in Ramona offered a set and Top End Performance.
https://www.racetep.com/automaker/bmw/short-front-bumper-kit-2002.html
Have fun...
Mark92131
1970 BMW 1600 (Nevada)
The spray when you drill the shocks is not that bad. Use a small bit to relieve the pressure from the bottom and fluid which is like antifreeze( not oil )will spray out Then use the small hole as a pilot and drill a bigger hole to pin the shocks in place where you want them
The spray isn't that bad, just be sure to wear goggles and do it in a cardboard box.
Or you could probably find some exhaust tubing of the right diameter, cut it to length, and drill a hole in either end.
The same can be done for the rear, it has three shocks compared to just two in the front.
Here's my blog post when I did mine, but it's an extreme tuck:
20160611_201626.thumb.jpg.983dce870aecaf
John Baas
1976 BMW 2002
2001 BMW M5
My Blog!
