circlips for clutch slave cylinder
I just ordered from Maximillian BMW and they were not that expensive, but I did see a C-clip kit at Harbor Freight that seemed to have a bunch of large size ones. You might be able to take your broken clip there and compare sizes. But not sure of width and quality will be the same too.
Here is the Max info - About $8 for two, but the size info seems common
Lock Ring       07119934186        28X1,5      2                  $3.96
1975 - 2366762 Born 7/75
See the whole restoration at:
They are a generic part (28mm diameter x 1.5mm thick), just not that common. You would probably need to go to a specialist fastener/ engineering supplier to obtain. Look at these on eBay for 10!.
https://www.ebay.com.au/itm/231331073821
28mm Inner 33mm Outer Diameter External Circlip Shaft Firmware 10 Pcs
Might as well go to the dealer though to avoid any hassle.
rtheriaque wrote:
