Rear vent window Grommet
mmichalik
Hi Guys,
I need some help with something that I've been chasing for a while and can't seem to find the answer.
I had to replace the window latch on my left rear vent window a few months ago.  When I pulled the bolt out of the window, the one that connected the latch itself to the window, there was a clear grommet in that hole that basically fell apart.
I've searched on RealOEM.com for the part but can't seem to find it.  I found the gaskets marked #6 (part # 51367040572) listed on this page http://www.realoem.com/bmw/enUS/showparts?id=2225-USA-07-1976-114-BMW-2002&diagId=51_3357
but no grommet.
So, my question is, was there ever a grommet there?  My car is a late July, 1976 production run, just in case that makes a difference.
If not, I guess it's possible that it was put in there by one of the previous owners but, I would like to get it fixed once and for all because the bouncing around of the window on that bolt drives me crazy and can't be good for the glass in the long run.
Any thoughts on this would be helpful and if I just need to put those two gaskets on there, then so be it.
Thanks,
Mike
My "fun" cars so far:        My restoration website:
     1976 BMW 2002a        http://www.2002and914.com
     1975 Porsche 914
Of you can't find specifically what you need at Walloth-Nesch, head to the hardware store and search the nylon and rubber washers. I've had a lot of luck at Lowe's and Ace Hardware.
Andrew Wilson
Also True Value if you don't have an Ace or Lowe's nearby.  I've found exactly that nylon washer at True Value--in white or black.  Good source for rubber washers too.
Thanks guys!
I'll hit up Lowes today and see what I can find.
     1975 Porsche 914
Driv3r, I got a bunch of those from Carl at La Jolla Independent last week as well.  I just wasn't sure that I wasn't missing something that would buffer the bolt where it goes through the glass itself.
Do these stop all the movement and everything?
     1975 Porsche 914
Since the purpose of the seal is to block water from getting in, the fibre washer is your best choice. Problem with rubber or nylon washers are that you need to torque the nut tightly to seal the glass and it might cause a crack in the future under vibration. Fibre washers are also used inside the water taps so they'll suffice.
