The quietest electric fuel pump for twin carbs ?
Road trip
6 minutes ago, halboyles said:
I've always had good luck with the Carter version:  https://www.summitracing.com/parts/crt-p60504
Rock solid and fairly quiet.
i have the same one and have been happy with it.  you hear a slight hum, but its not noticeable once the engine is running.  if i was doing it again, i would rubber mount it instead of directly bolting it to the car.
Rubber mounting a rotary style pump will be the quietest, Carter and Holley are the easiest to find and will work very well.  Make sure you get a good fuel pressure regulator, you only need 2.5-3psi and the pumps usually put out 6-7psi.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
(6-7 psi and the regulator restricts the flow
to 2.5-3psi) does this cause the pump to be louder ?
I've used these Pierburg electric fuel pumps with carburetors many times. These have the correct fuel pressure already, so no pressure regulator required. And yes, they're quiet, as long as you use a rubber mounting bushing. I just recommend wiring in a safety relay of some sort. I personally like the VW Rabbit one that already has a ATC fuse holder built in. All it needs is a RPM signal.
http://www.autohausaz.com/search/product.aspx?partnumber=90160810600
Edited by tjones02
Tom Jones
Not that I have seen, their internal pressure regulators (blow off valve like an oil pressure relief valve in your engine) is already open so it just flows a bit more.  You have to remember there is not much flow into the carburetors at anything less than wide open throttle in the upper RPM range. The carburetor float inlet valve is closed more than it is open.
1974 2002 Turbo
1988 M5
1986 Euro 325iC
You can find the Carter for around $34:  https://autoplicity.com/333952-carter-p60504-fuel-pump?1&gclid=Cj0KEQjw8tbHBRC6rLS024qYjtEBEiQA7wIDebrpcNgHZAE0oURT1vtRn4RwhurvSQVxEL3rKcPpp3caAsfy8P8HAQ
Since this model is rated for no more than 4 psi, you might be able to get by without a regulator.  I have on Solex and Weber downdraft and sidedraft setups.
BMWCCA  Member #14493
www.2002sonly.com
I'm on the Carter 4 psi pump band wagon.  I hung mine in line, above the diff., inserted it into the rubber line that feeds the metal return line on my '75.  I drilled one small hole and used a rubber isolater from amazon to try and eliminate as much transfer of vibration to the body as possible.  Used the Tii pump power feed under the dash and ran a single power wire to the pump. Grounded it under the isolator to complete the circuit.
(O=o00o=O)
Perhaps you didn't understand my post
the one your recommending IS the one
i have and it is loud
the stock mechanical pump with oem regulator works perfect on my 40's dellortos on a relatively stock motor.
otherwise i honestly dont understand why changing.
1985 XR4TI, 22psi ±300hp
Well, how did you mount it? Did you use a rubber bushing between the clamp and body?
Tom Jones
I have this one, and it's like having a meat grinder in the trunk.
I love it.  It's mounted directly to the rear bulkhead for extra resonance.
I can tell when there's junk in the tank, because I can hear the pump grinding it up.
Mwahahahahah.....
...not srs
