Replace diff in short neck 2002 with 320 diff
Brad Kuhn
I shall give you a short synopsis, and some guidance.
The 320 diff works, with the following caveats:
you have to use a rear cover from a 2002
IF you use a diff from an 80- 82 320, your best path is to use the 320 halfshafts, and put a 2002 outer cv on each.
IF you use a diff from a 77-79, you ought to use 1/4" or so spacer on each output.  This is best practice- you can probably get away without them, but your cv's may bind at full droop.
Guidance:  In the upper right corner is a 'search' window- tyoe "320 diff" into it and browse.  Lots of detail, long ago.
hth
