Bent oil distribution pipe - over head
7502
I have been ignoring this since I bought i last fall. The oil distributor pipe, or what ever it's called, on top of the head has a bend on the forward end. I can't figure out how this happened or if I should try to straighten it out. Unknown mileage, but the head shows 1980 and odometer is at 67K or 167K.  Seems to run fine.
I can't remember if there are any holes in the end to put oil on the timing chain or not, so you might want to check that, but even so I doubt that bend would cause an issue. Speaking of, looks like someone changed to a single row chain and sprockets, so you know you car has  previously had some thoughtful maintenance done!
There's a hole on the end of the tube which squirts oil onto the groove in the camshaft where the 'lock' rides. -KB
3 minutes ago, Son of Marty said:
The single row was used on post 2002 m10's so somewhere along the line your chain and sprocket have been changed, no big deal it'll work fine.
+1 - I put single-row set-ups on all my race engines (just a little less mass to spin....). -KB
Yes, sorry, didn't mean to concern you, just indicates that in all likelihood, your chain, sprockets, guides, and tensioner at least have been replaced at one point; in my opinion a very good thing! I see it as a sign that a previous owner cared properly for the car, and some of the important parts are newer than 40+ years old!
What is the VIN number on your block?  The factory replacement motor on my 1975 has a single-row timing chain, yours could be same.
Mark92131
