early heater valve to heater hose
rmoore007ri
Buy another one of the adaptor type hoses from Blunt (the long one) and cut it. If I build another early car I would make everything 18 mm to prevent headaches.  The heat in my 69 is really good - even with the small heater valve and core. Wonder why BMW changed it?
They had trouble with the small brass- on- brass valve.
I think the original BMW coolant spec had lube in it.
Plus, there's Scavahoovia-
VW gave up and fitted a gas burning heater
to T3's going up there.
The heater core in my Volvo 122 is bigger than the radiator...
and so on...
This sounded familiar to me - I just replaced something similar on my '72 240Z.  Nissan part number 14054-E3001 is just over 18mm at one end and just under 13mm at the other.  Might just work and is readily available for around $4.
Edited by \\\Mink
