Final Question of the day. Webber 45s Gaskets
Captain Manly
Ok, strange question I know but I am not a master engine mechanic.
Got my carbs rebuilt and planning to install them, I have 2 sets of gaskets to attach them to the intakes, one set is a typical paper thin and one set are 1/4" thick.  Is there a preference; am I suppose to use the thicker ones for improved air flow (still have enough room for the  brake boost)?
I know SQOTD, but its Monday and not enough coffee.
Thanks!!
Justin
The 1/4" is a phenolic spacer.  I suggesting using both if there is room, although I can't give  a technical reason why.  I know that sometimes it's necessary to make the linkage work.  My setup has them.
Edited by skyking96w
1971 Alpina 2002
=00=
You should use the thick phenolic spacer, because, well, its phenolic.  I think it helps prevents heat transfer from the head to the carb.  And you will need a thin paper gasket on both sides of the thick one.  They can be made from gasket material gotten from your local parts store.
BMWCCA  Member #14493
www.2002sonly.com
