Instrument cluster lights are dim
Mike Davis
The cluster is retained by two knurled nuts.  They are fairly large, around 3/4" diameter.  Should be easy to turn.  You will also need to disconnect the speedometer cable and the wire harness.  On my '72, there is also a ground wire that needs to be unplugged.  The cluster can then be pulled out from the front.
I changed all of my cluster bulbs to blue LEDs.
Good luck.
Edited by Tsingtao_1903
Sure the headlight switch rheostat is working? Unless the coil is broken, turning the knob clockwise should make them plenty bright.
Removing the cluster is easy as described by Tsingtao_1903
Andrew Wilson
Yeah, right. Somewhat daunting if you have never done it before.
Remove under dash panels, then working completely blind, snake your hand up behind the dash and try and feel the knurled knobs, and remove. Undo and pull back the speedo cable.
Then gently pull the cluster out from the front of the dash, but only a little way so you can get your hand behind to remove the round multi wire plug (fits on the ring of connectors, right side of my pic). From memory, I believe there's another single wire to remove (tach?). Installation is reverse, and good luck like trying to get the speedo cable re-installed, it's a 10 second affair or 10 minutes.
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
3 minutes ago, Mike Davis said:
Is there any way to contort one's body to see a little of whats behind the dash?
hehe.
Remove driver seat. Lay something comfy on the floor, then on your back skinny up under the dash as far as you can go. Then with the aid of an inspection mirror, you should be able to see the back of the dash that's not masked by the dash support/bodywork.
Getting the cluster out the first time is a bugger, but once you've done it the next time's not so bad.
Les
FAQ Member #17
I did plain white LEDs, came out good. They are super cheap on Ebay, came with a bunch of extras.  Matches my radio too.IMG_0673.thumb.JPG.ec7f9086b8d8bf5146f16328054cf1f3.JPG
Edited by Acid House
'86 e28 535i - Schwartz on Schwartz "Daily Driver"
'72 e10 2002 - In Progress "Go-Box"
Are the LEDs you used dimmable?  and where didja find 'em on E-bay?
Yeah I did red LEDs to match my head unit...and they are not bright AT ALL.  Going to do amber but again wanna know which ones to go with.
2018 BMW M550i X-Drive
1964 Volvo Amazon Wagon
http://www.project2002.com
'Bout 30 years ago, I had this exercise to replace the lamps because: (1)  I wanted them brighter,  and (2)  Red, like brand new E28s had...
Boy, you guys sure have it easy these days, with LED replacements in every color of the rainbow.
My '72 has four #194 small wedge base lamps.  I dipped them in some red gel-coat intended for theatrical lamps.  Worked like a champ for about 15  years, before the red coating started to darken, and go dim all over again.  Of course, that could be my eyes, but hey - I live and enjoy life in the state of Denial....
I do have access to amber and clear 194 lamps, not too expensive last time I checked.  Of course LED will be more money, and probably more light.
John T- I'll get back to you soon as I have a cost.
Andy the tail light guy says "Be Seen, and Not Hurt!"  [mailto:mobrighta@comcast.net]
Lighting Upgrades for E3, E9, E10, E12, E21, E23, E24, E28, E30, E32, E36, E39 - front & back
Tail Light upgrades keep them off your tail, out of your trunk;
Headlight film keeps your 'eyes' from being scratched out or broken.
As questioned before, are the LEDs dimmable in our cars?
Don
Don
