25 posts / 16217 viewsLast Reply
Hi Ken
I have a few questions regarding the subframe and trailing arms setup.
-Does it include hubs? I would like to use 5x120 wheels.
-What size of rotor and caliper can use?
-Are you using  common or available parts for stuff like, hubs, bearings, cv joints shafts?
Thanks
Hi Rod,
Yes the hubs are part of the kit and are available in 4x100 or 5x120.
The direct fit rotor and caliper for the 5x120 is the e30 m3 but some of the aftermarket kits will work but may require some fitting.
The wheel bearings and CV joints are OEM BMW e30 parts.  The halfshafts, stub axles and hubs are all custom made for us using 4340 chromoly, heat treated, and e-coated.  The stub axles are larger in dia. than the stock e30 and have 31 splines instead of 27 splines.
Thanks for your questions,
Ken
