ca 1971 ignition key . . .
rmoore007ri
This puppy has not had the ignition  key turned for 15 + years. Starting from fully CCW and turning CW it makes one "click" step and then another "click" step.
No position seems to be spring loaded.  What should each position actually do? Is there something I should try spraying into the ignition key slot?
bob
bob
I would, speaking of keys. I need to cut a new back up for my 107 86 560sl. Do you know where I go to do that. Thanks
Sent from my iPhone using Tapatalk Pro
I don't know what year BMW started putting in the steering wheel lock but if yours has it you may not be able to go beyond two positions.  May have to wiggle the steering back and forth to get the ignition to turn beyond locked position.
Glen
Edited by Glen Karr
Yup, prevents you from engaging the starter again. Normal, mine does the same. Switch is sometimes flakey, I replaced mine a few years ago with a NOS one and kept the old one in reserve. In my old days I'll have time to solder contacts when they are NLA.
Andrew
1971 2002ti, 1985 E30 320i, 1960 Land Rover 109 Ser 2, 1963 Land Rover 88 Ser 2a, 1980 Land Rover Ser 3 Lightweight
