WTB Black headrest or headrest cover ("eared" style/12mm posts)
Pete72tii
Because nothing is easy, I just want to note that there were two different headrests used in U.S. 1973 '02's.  The first style, first photo below, is a continuation of the basic style used on '02's from January 1, 1969.  Its more "tubular" in form.
The second style, second photo below, was implemented during the 1973 model year -- I know not when, but I suspect it was after December 31, 1972 -- and is more contoured to center one's head.  It's often referred to as the "earred" version, because the outer ends flare out like...ears.
At the same time that the headrest style changed, the headrest supports were increased in diameter from 10mm to 12mm.  I think!  Maybe Lars already said the change in headrest style and the change in support diameter were two independent acts.  If Lars said that, you should ignore what I said!
The 10 and 12mm support rod headrests are not interchangeable.  On the other hand, headrests of any color can be easily re-dyed (sprayed) black.  There are multiple threads discussing color-changing interior components and the dyes are quite effective.
Edited by Conserv
