weber, dell'orto, solex, mikuni, sk carbs they all work the
with side draft carbs. it does not matter what brand or from which car they came off as long as you jets and chokes are right they will work, granted they carb/s are in good wroking condition. they all have the same universal bolt mounting pattern.i have used and installed them all.
with down drafts there is only two brands to choose from weber and solex germany/italy. most '02 guys use the 32/36/, 38/38, 40/40. i have adapted 28/36 dcd, 36, 40 & 42 dcnf and they all worked fine.
solex came out with similar ones in europe. 32/32, 35/35 & 38/38 eeit's which is the same as the weber 38/38 and 40/40 in operation, synchronous throttle. both throttle plates open at the same time.on the plus side they are cheaper and commonly available in europe used or new. parts are easy to get too.
solex had hi-po down drafts too like the 40 or 42 ccif these are similar to weber dcnf series.
posted this just to inform some of you guys out there.
that there are a lot of options on carbs.
