Need to replace Weber 32/36.
mesapioneer2
The Weber 32/36 DGAV in my 1976 standard 2002 is tired. I am looking at replacing it with another of the same model.
Question -  Is the Redline kit sold by Blunttech jetted and set up correctly for a stock engine that lives at 1200 feet(Phoenix), but travels occasional  to 5000 or even 7000 feet?
Or, should I be looking at buying from someone who will re-jet to another prescription?
Thoughts?
Collin in Scottsdale
76 Chamonix
Question- what do you mean tired?  If the throttle shafts feel loose, they have plastic bushings that can be replaced.  You also have the option of replacing them with ball bearings.  I did that on my primary shaft, but the secondary seemed okay.
As for jetting, it is not hard to swap them around yourself.  c.d's prescription seems to be working well for me at sea level, but I have not installed the exhaust sensor yet, to really know how it is doing.
I have been inside mine to reset float height, swap jets, clean it out and stuff several times.  A little tweaking and it always seems to come around.  I am just wondering whether you actually need a new one.
Tom
+ 1 on rebuild.  I had the same Weber on my car from 1979 to 2013 before replacing it--and as it turned out I didn't need to replace it; I just rebuilt the old one and kept it for a spare.  And my friend Dene and I rebuilt a Weber that had been sitting outside (on an engine) for nearly 16 years--first we had to chip the mud-dauber wasp nests off it before cleaning it. It's now running just fine.
