71bmr02
All,
today i started tearing down a 70 and found these struts.  I've taken a few apart but all have had after market kyb or billy's.  is this strut rod (diameter 33mm) the normal stock strut rod diameter for boge struts?  any info appreciated
Thanks
Gale H
Gale H.
71 2002 daily driver
70 2002 malaga (pc)
83 320i (pc)
The top nuts look like Bilstein so very likely the inserts are as well. The actual strut tubes were made by a number of subcontractors to BMW. Boge and Sachs being two. You have Boge ones.
rtheriaque wrote:
Thanks all, hopefully the inserts will be good.
Gale H
this car has a set of argentine made jmf oil shocks on the back. They appear to have a removable end cap so oil and piston could be serviced.   still good condition, talk about old school.
Gale H.
70 2002 malaga (pc)
83 320i (pc)
33 maybe a bit more or less but huge.  that size rod has to have a really positive effect on stabilizing the front albeit at the price of a little extra weight.  If theyre still good, i'll use them on my car.
Gale H.
70 2002 malaga (pc)
83 320i (pc)
