tii Crankshaft Pulley Dilemna
Greggotii
My tii's motor came to me in pieces, and I'm having some trouble with the crankshaft pulley on the front end.  Is there a sleeve, or extra piece that fits between the tii's front pulley and the crankshaft itself?  I'd take a picture, but it's all at the machine shop right now.  At first I thought the previous owner had given me the wrong pulley, but now I'm not sure at all, and I can't find a decent exploded diagram of the engine. Thanks for any help!
it would be better if you could show the
other side of the pulley that has the rust.
it looks like a tii pulley with an AC pulley on
the back side, the side you are showing.
the picture that shows the crankshaft in
the block is complete and the loose part
shown on the tool box is the next part to
be put on the crankshaft after the front
cover goes on the block.
stone
stone racing co
phila pa 19123
The rusty piece is not a Tii part, the first thing outside of the seal surface is the toothed pulley for the injection pump drive belt, ALL of the V belt pulleys are outside of the plastic cover over the belt.  The pulley on the tool box is a Tii hub with a single grove pulley for a NON A/C car.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
tii hub with A/C pulley from my 72tii 2762332 engine (converted to carbs in my 69)
Same engine rebuilt and converted to carbs.  I used an early front pulley.
4A2F13C1-3057-486D-A488-9A7D3558706D_zps
