TDC Should Point to Cylinder #1
Captain Manly
Yes, that's correct. Open the valve cover and check that both #1 valves are closed and you're pretty close. You can set it real close to TDC by pressing a probe (stiff wire, long thin screwdriver, etc.) through the #1 spark plug hole onto the cylinder top if all your other indicators and pointers are unusable.
Jerry
no bimmer, for now
TDC looking at what?  IF you  remove the valve cover you will see a line marked on the camshaft right behind the chain sprocket,  this should be directly under the oil spray bar. This would be TDC cylinder #1.  If you are looking at the flywheel the "bead" on the flywheel is 25 deg BTDC (cyl 1 and 4)  on the flywheel you should look for a line and OT marked next to it.  If you are talking about where the distributor rotor should be pointed at TDC #1 then it really does not matter. If you are running a distributor that has a vacuum advance can on it I usually mount the can so it is pointed at the right side of the car, The distributor rotor should be pointed at the small notch on the top of the distributor body at TDC #1.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
