ID this cam
356ruler
They're marked on the nose-
there may be a 2 on the flange's outer perimeter, on something that started as a stock cam,
or some numbers stamped/ engraved underneath
the cam gear itself, or on the snout that sticks through the gear.
The one exception is that if you find Dr Schrick cast into the blank, then it's a Schrick.
The identifying numbers are still on the nose of it, tho.
hth
