Hey, Al Canuk, how many sq. ft. of sound deadening stuff do
Do the whole car? I'm going to do behind the door panels and backseat panels, under the back seat and under the head liner. And, of course, under the carpet. I thought I might just ask if you have the figures handy. Otherwise its the tape measure and the calculator. (and I made a C in geometry so I probably still won't get it right)
I don't know. I'll be finding out soon enough though, as I plan to paste the inside of my car with B-Quiet Extreme in the not too distant future. A customer used it in his 62 Bug, and was floored by how well it worked.
Perhaps Keith knows how much you will need? He just soundproofed Stella recently. www.my2002tii.com
Al
try foil backed foam HV/AC air duct insulation. I was in the shop at Carolina Rodders in Greenville, SC recently (super cherry auto restoration outfit)and they were using the stuff to insulate the entire passenger cabin of several very top notch resto. cars in their shop (a $75m!!! '32 Ford coupe resto. w/ LT1 drive, a back-to-original '71 VW Bug, a sweet '69 Chevy Camero to name a few; there were plenty of others). If you decide to try this, be sure to get the foil backed FOAM insulation, not the foil backed plastic bubble wrap type stuff. Carolina Rodders was using approx. 1/8" thick foam off of a 5 ft. wide roll. Silver foil side up, foam side down, attached with "Liquid Nail" adhesive. It comes in diff. thicknesses and in diff. width rolls. Its light and a whole lot less expensive than Fat Mat, DynaMat, etc. Because it is not as dense as the Fat Mat type materials it probably will not be quite as effective as a sound deadener. But light weight and CHEAP works for me. If its good enough to put in a $75m '32 coupe restoration, its good enough for an '02 restoration on a "slightly" smaller budget...I plan on trying it.
