1976 2002 FS in Seattle
fastb27
$10,500 OBO
Mechanically very well maintained, looks and runs excellent.
5 speed gearbox
Weber 38/38 DGES carb
No cracks in dashboard
Needs paint and some attention to rust
Car was, and is, well loved. Always stored inside. BMW CCA enthusiast.
I'm more of a "wrench" focused on performance and driving pleasure, as compared to a "concours" person focused on appearance.
Looking for someone who knows and appreciates 2002s and will continue to take good care of this car. No shipping, no trades, no tire kickers, no stories, no dreamers. Serious inquiries only.
Engine upgrades
• New pistons
• Cam regrind, TISA profile
• Ported intake manifold and cylinder head
• Lightened flywheel
• Oil pump with 15psi increased pressure
2002 ti (one i) clutch and pressure plate (larger friction area)
• Oil baffles in sump, to prevent oil starvation during spirited cornering.
• Air injectors removed from exhaust manifold (improved exhaust flow)
Suspension upgrades
• Suspension Techniques front & rear sway bars (22 & 19mm)
• Firmer & lowered springs
• Front strut tower brace
• Negative camber plates, 0.5 degrees (better turn-in & cornering)
• Feb '16: Replaced Mac Strut bearings
• Polyurethane bushings
Brake upgrades
• 320i ventilated front rotors
• 320i calipers, cylinders and master cylinder.
• SS brake lines
• Feb '16: Replaced front rotors, calipers, pads and brake fluid.
Other upgrades
• 3.64:1 differential (from a '74)
• Nardi steering wheel
• Oxygen sensor added to downpipe, and gauge added to dash/console.
• Oil pressure port added to oil filter bracket and back of cylinder head. Oil pressure gauge added to dash/console.
• Pertronix electronic ignition points
• E30 "bottlecap" wheels. Original "styled steel" wheels available.
• Cibie H4 halogen bulb headlights (bulb separate from headlight lens, better lighting)
• Front air dam
• Repainted in 1995. Needs attention.
Assorted spare parts available:
• Euro style flush mount front running lights
• cylinder heads,
• half shafts,
• 3.9:1 differential (only used in 1976 model)
• 4 speed gearbox,
• original styled steel wheels,
• Basket weave wheels, painted black, +1"
• Instrument cluster
• Black bucket seats
• Distributors
• Many others
Also Available:
• Original factory shop manual,
• Haynes repair manuals,
2002 history books,
• Decades of Roundel and Zundefolge magazines.
My pics show the good and the bad. I want to honestly portray the car's condition.  When you see the car in person, it will be as you expected.
More pics posted at:   http://s1079.photobucket.com/user/brianmcc1922/library/?sort=3&page=1.
Edited by fastb27
