Upgraded 2002 accelerator pedal SS Heim Joint pull rod 66-76
harry6422
$60
Rancho Cucamonga, CA (91737)
This is a direct replacement for 2002 pull rod BMW part #35414440125, this is for carb auto or manual cars, Tii is a different part number.
This upgraded pull rod is stainless steel is custom bent it to exactly match the factory rod, ends threaded and steel heim joints with jam nuts installed . The bolts are SS with nylon lock nuts, 6mm on the bottom to attach to the pedal box and 1/4 in on the top to fit the lager hole in the carb shaft. Anti size was applied the threads and you can increase the length of the rod by adjusting the joints. There is NO PLAY in these joints but they allow for side movement from Minor misalignment, body flex or engine movement. Now the pedal and the carburetor move as one NO PLAY!!! $60.00 shipped to any USA address
contact creativesales.comments@gmail.com for info, PayPal OK.
"I have not made these for some time , but after a number of members expressed interest in the old post I now have them back in stock 7/29/2016 "
Thanks
Edited by harry6422
1975 BMW 2002 Taiga
2000 BMW M Roadster evergreen
