Tii Brake Master Cylinder...Genuine or Generic ??
Russkcpa
Sorry if this has been kicked around
My 1973 Tii MC is leaking and Bavarian Autosport has a genuine BMW Part 34 31 1 120 478 for $335
I see many generic brands in a google search for lesser amounts. I don't mind spending the $335
Just want to know what you think
Thanks
Russ
Edited by Russkcpa
1973 Tii Turkis
1983 320is Henna
Save yourself a little money and just buy the master cylinder made by Ate which is available from many parts vendors.  It's the same part that you'll end up getting from BMW.
http://www.rmeuropean.com/Products/34311120478-MFG4-V5471.aspx
You'll also need to buy 2 of the rubber grommets: 34 31 1 121 911
and maybe 2 new plastic elbows: 34 32 1 102 282
and probably some new brake fluid hose: 21 52 1 163 714
and maybe a new brake fluid reservoir: 34 32 1 112 399
and of course there's the brake fluid: http://www.rmeuropean.com/Products/81229407512-MFG4-V5471.aspx
and maybe a pressure bleeder like the ones made by Motive.
Sorry, scope creep :)
Edited by JohnS
1973 tii Inka - Oranjeboom
1974 tii Fjord/Primer - The Thrasher (my daily driver since 1986)
Don't buy a "generic".
 Buy a name brand like ATE, TRW, Lucas (yes, that Lucas, but the brake division is fine) or FAG or likewise.  Probably $200,
and if it's ATE, it'll be what's in the Genuine BMW white box anyways.
Beck- Arnley will likely be one of the above, for less $.  Likewise, Raybestos or other "known" US brands.  Most of the time.  Not guaranteed.
Most online vendors let you return things if you say "What's in the box wasn't what I was expecting" especially if you're ordering a different
version of the part at the same time, so sometimes I play that game, if the savings makes a difference at that point in my life.
Centric will be made in China.  And may work fine.  But I'm a traditionalist.
What I've found, anyways...
