electric fan installation
2ohoh2
I am installing a electric fan in my car and I was wondering what part of the ignition people tend to tie the relay wiring into so that it gets power when the ignition is on? I dont want to overload anything have have problems with fuses. any advice would be appreciated.
The fan draws enough power that you should run a wire directly to the battery (or main battery cable at the starter if you have the battery in the trunk) and fuse it before the relay.  You can then use the a circuit controlled by the ignition switch to energize the relay as the additional load will be minimal (circuit #15 is live with the key in the run position) You should be able to pick up that circuit at fuse # 5 on the 6 fuse box or fuse #10 on the 12 fuse box.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
that's what I did... except i ran a few things off it.
- Aux Fan
- Wideband
- VDO Gauges
- Radio antenna
FYI: i had to change the location of the distribution block after realizing it interfered with the "under-dash" pieces.
Edited by MildSeven
picked up what i thought was a sound Verona Red '76
The Refresh Blog: http://www.bmw2002faq.com/blog/155-76-verona-red-refresh/
I'm using an ignition switched wire in the engine compartment that was for the now-removed emission related relays on my 76 (green/white wire)
I installed a small 4-fuse distribution block next to the relays by the battery and put the fan relay there as well.
https://smile.amazon.com/gp/product/B01BV1MS1K/
I'll also using be using the fuse block for the electric fuel pump and fog lights in the future.
John Baas
1976 BMW 2002
2001 BMW M5
My Blog!
