Dashes 1st Then Windshield Unless?
Captain Manly
Ok, I understand that one should install the dash first before the windshield because of the 2 mounting screws mounted in the front edge - center of the dash. However, if one has an old "L" shape screw driver, would that suffice?
Also, if one uses the new self locking tab/plugs instead of screws would that suffice.
TIA!!
Justin
Yes you can get the screws in after the windshield but it's a bitch I had a small off set ratcheting screwdriver that helped quite a bit if I was to do it again I might take Steve's  approach and leave them out.
George S Patton
