Plastic Wiper Blade Mounts
silasmoon
Howdy Intrepid 2002'ers
So we finally had a bit of rain recently, and I realized that I desperately needed new blades. I dropped into the local Autozone and got some 15" BOSCH SUPERMEGA-RAINBLASTERS and walked out. When I went to change them in the rain I noticed the attachment bit wasn't the standard c-shaped hanger on every car I've ever owned.
Instead I noticed some sort of cheap black plastic tip on my metal wiper arms that mounted to the BOSCH wiper-blades the PO had installed. In my absolute genius I seemed to crack this mounting bracket that was on the tip of the metal wiper arms. It looked like it was joined via a hole that the tip popped into. Does anyone know if that is a BOSCH part, or if that was actually part of the wiper-arm assembly itself? I looked at RealOEM and didn't notice anything marked as such.
What wiper blades are you using? The originals look to be Bosch 380's which are now defunct.
Usually you get a bunch of different plastic doobries in the package with the blade.
 The end you want has a C loop the snaps over the rod on the blade and then pushes onto the end of arm and locks into place in the small hole at the end.
rtheriaque wrote:
