Shop manuals.....
For those that have seen both versions-
Are there any differences between the two volume and one volume manuals for our 2002? Did they just put more pages in the single binder or is there really more to the two binder set...??? I have the single binder one and see the double volume one every once in a while. Just curious.
Thanks
Kevin
volume II - tab numbers are not consecutive.
Vol. I has 00, 11, 12, 13, 16, 17, 18 & 21 (one tab), 23, 24, 25, & 26
Vol II has 31, 32, 33, 34, 35, 36, 37, 41, 51, 52 & 54 (one tab), 61, 62 & 63 (one tab), 64, 65, 71, 72, & 99
I can ID what's covered under each tab if needed
I'll go out in the morning and see what mine has. I've often wondered what the differences were, might be and so on. Funny that they would put out two different versions on the 'same' manual. I remember I bought mine from the dealer just before they were discontinued back in the early 80's. Too bad....
I know Mercedes also has discontinued their paper manuals. They are on CD as well, but the quality of them is not what the paper one is. I'm glad I have the 'five volumes' for my W126.....
Thanks again-
Kevin
through numbers 71/72. 11 is engine, 12 is engine electrical, etc. 31 = front axle. does this sound like yours Barry?Mone ends with ch 71 : fitting triler hitch to electric system- very important!
602 1802 2002", part # 01 51 9 699 551 - there is no publication or copyright date that I can locate;; volume I and II split between tabs 26 and 31. This specific two volume set was purchased new at the dealer in the mid 70's by a long time friend for servicing a round light that he owned.
BTW, the manual transmission section (tab 23) covers both Porsche and Borg-Warner synchro's AND close-ratio 5 speeds, including a section on adapting the 5 speed into a 4 speed car.
Tabs:
00 - Maintenance and general hints
11 - Engine
12 - Engine-electrical
13 - Fuel supply and adjustments
16 - Fuel tank and lines
17 - Radiator
18 - Exhaust / 21 - Clutch
23 - Transmission-manual
24 - Transmission-automatic
25 - Gear shift mechanism
26 - Driveshaft
31 - Front axle
32 - Steering and wheel alignment
33 - Rear axle
34 - Brakes
35 - Pedal assembly
36 - Wheels and tires
37 - Integrated suspension systems
41 - Wheels and tires
51 - Body-interior equipment
52 - Seats / 54 - Sliding roof
61 - Chassis electrical
62 - Instruments / 63 - Lights
64 - Heating and air conditioning system
65 - Radio and accessories
71 - Equipment parts and accessories for engine and chassis
72 - Equipment parts and accessories for body
73 - Paintwork
French and Italian, although the manual is only in English and spelling and usage are "American english", not British.
The index layout is basically the same as far as the names/numbers of the sections.
The 02 set has the first book with sections up to & including 26, and the second book has 31 thru the end.
The NK book has all the mechanical sections in one book, and the body stuff (sections 41 and above) must have come in a second book, which I never got.
The introduction page of both cars manuals has a statement at the bottom:
"Published by Bayerische blah blah blah.. All rights reserved. Reprints only allowed with the written consent of the publisher."
There are "alteration" sheets inserted into the manual, each having a date on the bottom. These were used to update the manual to reflect product/service changes or make corrections.
With the factory manuals you have, what sections are empty ?
Paper books are great -- I use CD info all the time, but the paper has a real value to me.
So I guess the two volume set is just a two volume set of what I have under one.
Seems that they are equivalent.
Kevin
