2002 Emblem how shiny should they be??
jrhone
Should they be almost chrome and polished like all the other brightwork?  My emblem is more dull than everything else. I was thinking that it would look good shiny and polished or chrome and maybe new ones are??
2016 BMW 535i M Sport
1964 Volvo Amazon Wagon
http://www.project2002.com
Depends on which emblem you have on your car.  If it's one of the original metal ones with raised dividers between colors and raised BMW letters, the colored sections were painted with gloss paint.  You can use Testors model paint to duplicate the colors; black and white are easy, the blue is Testors either 1111 or 1112.
If you have a later replacement emblem, it's flat (no raised dividers) and coated with shiny plastic that contains the colors, and peels off after several years.  With those, you just buy a new emblem--although you can use the above paint to touch 'em up.
I believe he's referring to the long "2002" script, Mike.  They seem to have a somewhat satin-ish finish when new (at least the replacements do) vs. chrome-bright.
John in VA
Yes I bought new roundels. This is the "2002" script emblem. Can I hit it with the oven cleaner to strip the clear coat then sand it and polish it like aluminum?  Or have it chrome plated?
Oh...I was thinking Roundels, not emblems.  But oddly enough, the 2002 emblems came in more than one finish too--probably inadvertently due to more than one supplier.  I've seen 'em nearly as shiny as chrome when new, then almost to a satin finish.  Same with roundie grilles.  I have a couple that are very shiny, and several more that have a matte finish.  And over the years, like the beltline trim, the emblems become kinda dull and clouded.  They can benefit from some wet sanding to remove the anodizing, the polishing and some clear coating to preserve the shine.
