Linkage for 2002TI manifolds.
69NEWCLASSNH
Hey Guys,
   Anyone know of a plug and play linkage kit that will work with my 2002TI manifolds.  I want something tried and tested that i can just install without any issues.  Was thinking of getting an interconnect kit, and then figuring the linkage out for the rear carb, but a kit which I know works would be preferable..
Thanks in advance!
EDIT:  This is for DCOE40s if that makes a difference
Edited by 69NEWCLASSNH
Hmm,  plug and play.    If you have a NK, then I'd suggest you start looking for stock NK ti manifolds and linkages.
My Solex carbs came with (2) NK manifolds and I traded another FAQ'r the rear NK one for a new 2002ti one (without the vertical linkage).
Lars Alpina in Germany will have the (IMO) best details on what you need for your NK with dual Webers.  Now that I think about it, Peter here in the US has an 1800tisa with dual Webers.  Maybe he can be of some assistance.   Daniel (Mojojoy) is another very helpful FAQ'r.
Look for these manifolds
Ok - you have a 2002-  not a NK.   My advice is to try to find the factory 2002ti linkage bits and use them.  Lars offers very nice reproduction bits.
My 69 uses a combination of factory 2002ti parts and Lars' parts with the Solex 40PHH carbs.
F69203AB-CBE8-4DCB-ADBC-BC3CAC5AF788_zps
I have not done it but it should work fine, remove the pedestal on the back and there should be a clevis pin that will make up to the 2002 linkage then bolt the booster to the 2002 mount and replace the master cylinder with the right one and your good to go
George S Patton
