Car won't turn over
Crumbod
The 74 model year had the seat belt interlock system, most people figured out early on you could just unplug the seat sensor system and the car would start with out having to buckle up this works fine but the start signal would still go through the under dash relay this relay has likely worn out and can't pass the current to the solenoid, do a search for 74 2002 seat belt interlock there is plenty of advice  on how to by pass the relay.
George S Patton
This might be the right direction . I just got a new seat belt for the driver side. But I kept the old belt and buckle and did not disconnect the wires, and kept the belt "buckled" on the rear floor.. It seems that I should be able to start the car in this scenario right. I never buckled the belt at all until now since I have owned the car and did not have this issue. I am going to unbuckle the original belt and see if this resolves the issue.
