Roundie and square tail distributors
stricht8
Lots of variations in distributors through the years with points in different configuration and different cap arrangements. I would send Blunt your distributor number and get him to identify the correct parts. Even the condenser varies with a square or a round hole through the body.
rtheriaque wrote:
There are 2 styles of cap-  'early' dizzy has a tab that sticks up from 1 of the hold-down clips.
'Late' has a notch cut out of the barrel of the dizzy, and the cap has a tab.  And is a vw part
I think they changed in '71,  but don't quote me.
Rotors all interchange.  and are vw.
Now, the actual dizzy spec varied a lot...
Rotors all fit, but there are two kinds to choose from.
One has a wider tip, for the added advance associated with vacuum advance distributors, if I understand it correctly.
With rotors there is also a difference in resistance.
Bosch typically marks them with either an R5 or an R1.
My extra VW bits come in handy.
EDIT-- the R5 rotor is what the manual calls for.  It makes for a longer spark duration than the 1K rotor.
Edited by '76mintgrün'02
Don't forget the rev- limiting rotor, Tom!  Those were NLA back when I started, but seem to have come back from the dead
(maybe Botch found a big warehouse full of 'em they forgot they had?  Sent one to China by accident?)
and the "guess it's time to do the driver's side mount" rotor...
I'm sure I'm missing a few...
hee
Great info presented. I would start with WHICH motor do you have in the car as a base point and then decide which path to pursue (updated electronic ignition or old school). So many times I go to a car show and see a non-original motor but somehow it is believed to be original. But thats OK & thats part of the fun of owning a 40yr + old car. Personally I went with updated via Crane ignition and have had zero problems. Call me if you get stuck.
Thanks,
Max
Maximillian Importing Company
www.bimmer.com
800-950-2002
classicbmwparts@gmail.com
