Random wire near starter?
2002VT
Hello all!
i was moving around and bleeding the clutch this weekend - then ready to drive it when it would not start. Just clicked. Grrr. I'll return my new battery to see if I killed it when I accidentally tried to start the car while it was in first gear (prior to the clutch being fixed) and it crept forward two or three rotations.
I guess maybe I killed the starter - maybe. But that would be weird.
Anyway, here is the random wire coming from the same lead that goes to the starter...did I knock a wire free?
looks like the coolant temp sender wire.
edit.. dug up a photo from my disassembly album.
You can see it plugged in here at the bottom/center of the photo on top of the coolant divider.
Edited by MildSeven
picked up what i thought was a sound Verona Red '76
The Refresh Blog: http://www.bmw2002faq.com/blog/155-76-verona-red-refresh/
Thank you so much for the help. I cannot quite see it - but I am on my phone. I'll check it from my PC tonight.
I will ill swap out my cables tonight, and I got my battery tested too. Last issue to check will be a starter.
JD
That wire doesn't look long enough to reach the temp sender. What colour is it? I can check against a wiring diagram (O am colour-blind so it is best you check it :D)
rtheriaque wrote:
ya, I didn't consider the length.
In the photos, the only colour I can make out is brown.
