Tii "D Cam" Replacement Part
classicman
Hi Guys
The the shaft of the D Cam in the Tuna can on my 74tii is pretty badly worn. I've looked in Realoem, W&N and Rogerstii and can't find a part listing for this and the brass bush that goes with it. Any ideas on the part number and where I can source one?
74tii - Alpina A4 Spec
71 3.0 csl - to be restored
OP - don't be shy to ask Rob for tii-specific parts.  If your throttle body cam is well worn, closely inspect the coupling that secures that shaft to the lower vertical pivot.  Also check the tiny return spring inside the throttle body housing (tuna can).  A weak spring will cause running issues.
You might still be able to purchase some of the factory tii linkage bits from BMW sources.
Thanks. I've just replaced all of the other linkage rods, which is why I've checked this one as well. Who's Rob?
