Power steering in a 74 2002
mamsalthani
Hey guys, 2002 owner from Qatar here.. im currently building a 74 model with a toyota supra 2jz engine installed in the car.
it sounds great!
Anyways.. the car doesnt have any power steering and its hell to drive, do any of you guys know a good power steering system i can install to make the car a better drive?
Thanks!
What tire pressure do you have in the front tires?
Put 34 to 36 lbs in the fronts and I bet you'll find it's much easier to steer. Put about 2 pounds less in the rears for best handling balance ( as a general rule)
Ed
'69 Granada... long, long ago
'71 Manila..such a great car
'67 Granada 2000CS...way cool
In the late 70's I met a Viet Nam vet in the bay area who had lost 3 fingers and a hunk of his left hand in the service, he had adapted the pump and power steering box from a Bavaria and it looked like it fit the steering box mounting on the 02 well, I don't know if you could find any of that gear in usable shape anymore but it has been done
George S Patton
I've been wanting to try this:
http://www.fordmuscleforums.com/all-ford-techboard/538585-100-power-steering-yes-you-can-use-column-electric-power-assist-system-epas.html
If you can get access to these parts where you are it may be an affordable way get power steering.
'69 2002
'59 MGA
'67 Chevy C20
“Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.” - Mark Twain
