Eimis Savickas
Removing rear driving flange question
4 posts in this topic Last Reply
Once again, I'm in need of help by BMW2002FAQ community...
Changing rear wheel hub studs (hopefully - the right way) by removing the driving flange.
So far - was finally able to remove axle nut (it was pain in the butt...)
Went to autozone and got my self a 3 jaw puller/extractor tool to rent.
Got it to grab side of the hub...
Now question - how do i keep tightening the puller, because it turns whole axle since there are no brakes.
Is there some sort of trick to remove that hub or am I missing something here...
Please help.
These might help, when i did mine, i stuck a breaker bar between my studs and then yarded on it.  Tapping the puller on the end with the sledge hammer was the key once it was tight.  Just took a small tap and away it came.
Edited by Zorac
arghhh thanks!
I read up the first one before I posted but missed the second one while searching for answers...
will try those methods tomorrow.
20 minutes ago, Eimis Savickas said:
arghhh thanks!
no problem, i find sometimes unless you get the search terms just right, it can be hard to find the right thread.
