Questions about plumbing with -AN fittings
I'm buying the bits and pieces to plumb in an external oil filter, thermostat and oil cooler and am having trouble finding the proper connector fittings. The thermostat, adapter plate and external oil filter housing are all -AN 10 Female. I can only find -AN female hose ends in the Earls catalog (I couldn't find them in the Aeroquip catalog either).
Are there alternate suppliers of hose end adapters that will put a male fitting on a hose? Otherwise I need a pile of male-male adapters (at about $7.00 each) OUCH!!
Thanks!
John N
URL: http://bakerprecision.com
What you are finding is the normal/recommended way to configure hoses.
The hose end with the female AN flare fitting is your best bet, I don't think you'd help yourself by going to something different. The female hose end is made to turn when tightened on to your M/M adapter assembled to your part. Be sure to get the correct M/M adapter threads, filter mounts are machined with a variety of female threads: AN o-ring; NPT; BSP, etc.
Do you have any feelings about Earl's "Auto-Fit" vs their "Swivel Seal" product lines?
I'm going to be into this sucker for >$300 for the cheaper line, is the extra money worth it??
Thanks!
John N
Haven't purchased from them yet but have their catalog and they have an extensive offering of AN and associated parts. www.pegasusautoracing.com
I'm not experienced with using both, so I can't really give solid advice.
That said, I'd trust Earl's Swivel Seal -- a more traditional design with threaded nipple (like Aeroquip) rather than the barbed Autofit design.
If you are having someone assemble them for you, ask about their preference. Often, the places that do Marine or Industrial hoses can whip this stuff out + pressure test the finished hose for you.
This stuff does add up $$$ !
