Posted (edited)
Price: $80
Description:
This upgraded pull rod is stainless steel  is custom bent it to exactly match the factory rod, ends threaded and  steel heim joints with jam nuts installed . The bolts are SS with nylon lock nuts, 6mm on the bottom to attach to the pedal box and 1/4 in on the top to fit the lager hole in the carb shaft. Anti size was applied the threads and you can increase the length of the rod by adjusting the joints. There is NO PLAY in these joints but they allow for side movement from Minor misalignment, body flex or engine movement. Now the pedal and the carburetor move as one NO PLAY!!! $80.00 shipped to any USA address
contact creativesales.comments@gmail.com for info. I am now only using the  Zelle payment app to receive personal payments , most all banks and credit unions offer this service with no fees . You can send payment "old school" by sending me a USPS money order, shipped when recivied, or a personal check shipped after your check clears my account.
I have pull rods for both carb and Tii models, let me know what you need.
P.S.  After almost 3.5 years I am now making pull rods again and have a few in stock ready to ship.
Thanks
Harry
Edited by harry6422
updated info
1975 BMW 2002 Taiga
2000 BMW M Roadster evergreen
  • 4 months later...
  • 1 month later...
Select No. Description Part Number Supplement  Qty per car  From   Up To  Price Core Charge Notes Qty To Order Buy now
  01 Bracket 35414440130   1 03/1966 07/1977 N/A no charge CALL
  02 SLIDING PIECE 35414440131   1 03/1966 07/1977 N/A no charge CALL
07 Bush 35411103893   1     $5.74 no charge
  08 ROD 35411103814   1 03/1966 07/1977 N/A no charge CALL
  09 Lock Ring 13214440136   1 03/1966 07/1977 N/A no charge CALL
10 TENSION SPRING 35411104043   1     $10.59 no charge
15 Sheet metal screw 12138530118 B6,5X16 2     $1.13 no charge
  16 SNAP RING 07119987605 R8 1 04/1971 07/1977 N/A no charge CALL
17 Shaft 35411109924   1 04/1971 07/1976 $66.10 no charge
  18 SLIDING PIECE 35411103775   1 04/1971 07/1977 N/A no charge CALL
  19 Bracket 35411103778   1 04/1971 07/1977 N/A no charge CALL
Check all / Uncheck all
1975 BMW 2002 Taiga
I am thinking about purchasing two of these. One for my tii and one for my dad's 72 carbed model. Shoot me a message when you can.
Chastity: the most unnatural of sexual perversions.
74 tii, 99 BMW R1100R, 99 E320, 01 S4 Avant
