COOP
Correct vent window center caps...
13 posts in this topic Last Reply
So I ordered new vent window center caps for my '72 tii as the originals look a little chewed up. All roundie 02s that I've ever owned have had the "chrome" rings in the cap like in the first picture...but the ones that I received are just plain black plastic which doesn't look so nice, see second pic. Are these still considered "correct?!" I wouldn't think so...
COOP
I am finding that altho you may order something from BMW, or Mobile Traditions, the items are NOT always ORIGINAL equipment. The covering for the trunk panels, from BMW, is not the same as the original material, just grey vinyl, and the new 2002 logo for the rear, altho BMW, a cheaper repo. thin material. Here too it seems with your knob insert altho functional, is not the same as the original item.
I think you nailed it Russell...It's disappointing because while BMW cheapens up their replacement parts and alters them to non-correct specs, they have simultaneously hit the buying public with a 30-40%, across-the-board price hike per Roger (Roger's tii). I'd be less miffed about this obscene increase if the parts were up to snuff in both quality and correctness...seems like a bit of a double-f***ing to me. I guess the counterpoint to my kvetching would be that we should all be grateful that we can get replacement parts at all...
COOP
I guess after 40+ years there aren't enough live bodies left that know what "Original" is for these cars.
But I can see based on the limited quantities of any single part to be made, warehoused and kept on the books, the cost can be quite a bit higher.  Unless the part is used on another car, open your nose because you will be paying thru it, on hair at a time.
(edited)
We don't quite get the same "love" that Mercedes-Benz gives to their owners of classic cars re: number of available parts, but the prices for ours are relatively affordable, when they are available.  I, too, prefer to get the same part that I'm trying to replace vs. a new iteration of it, like the vent window center caps.  Someone was making them from metal within the past decade - shiny ring with the rest painted black (bimmerdoc.com or Jaymic).
Edited by John_in_VA
added info
IIRC the original caps have a metal trim ring held onto the plastic base with little bent-over tabs pushed through holes in the plastic.  I think with a little care you could transfer the metal rings from your chewed up bases to your new covers by making a few holes in the new one to match the tabs on the metal ring.
But to answer your original question, no US cars came with plain ones--they all had the metal trim.  Interestingly, 2000CS coupes used the same cover, but it was all chrome-plated plastic.
This is great! Very helpful...Thanks!
COOP
You do have the RARE cap removal tool, right COOP?
It's funny, the proportions look different on the all black cover as well.  The ring looks bigger than those with the metal insert.  What did you wind up doing with yours?
This thread made me look closer at my covers and I will polish the rings a little, now that I know they are real metal, as opposed to the mylar stips on the doors.  Those are kinda cheesy, imho.
Unfortunately a PO of my car did not have this special tool and tried to pry the caps off with a little screw driver.  I was mostly able to moosh the damage back to flat.  Luckily this stuff all blends together on my car.  It is a 'used car'.
Tom
(edited)
This what you're talking about?
UPDATE:  I have to agree with Tom.  None of 'em would be good enough for COOP's car.
mac.
Edited by mac
reality
yup
the two on the right show evidence of someone not knowing about the little hole on the back of the knob, where the special rare removal tool is inserted.
Actually it looks like all those caps have been removed by prying them out from the front.
Some of them were just done a little more carefully.
Tom
(edited)
While few seemed to know about the hole in the back of the knob, even fewer knew of the circle on the outer perimeter of the knob's front letting you know where said hole was located.  I don't have anything near as fancy as Tom to press out the center cap.  An Allen wrench or custom-formed length of wire has been my go-to.
Ha, I would have thought that little mark was left by a prying tool in the hand of a PO.
Re: fancy... welding rod and a piece of a nail that was sitting on the bench.
It was made during one of those times when I really should not have been working on the car in the first place... with other things on my plate.
Funny how extra little 'opportunities' pop-up during those procrastination/indulgent 2002 times.  "OOooh, I need a tool for that!"
