1974 BMW Bavaria
catlin
Two years ago the barn finder sold it to his close friend for him to fix up. He never got around to it, so we picked it up from him. We began working on it but our novice skills were not good enough for some of the repairs so we took it to Marks Motor Mechanic in Walworth.
The car has new
Steel brake lines
Brake pads (front and rear)
Brake calipers (front and rear)
Fuel filter
Spark plugs
Wire set
ATF fluid
Trans pan and gasket
Weber carburetors
Differential fluid
Oil and oil filter
Brake fluid and booster hose
Intake manifold gaskets
Exhaust system (very quiet)
Starter
Tires
Wipers
Fuel Lines
Vacuum lines
Battery terminals
Tail lamp bulb
Brake fluid
Wheel bearing seals
Water pump
Upper and lower radiator hoses
Radiator
Valve cover gasket
Drive belts
Thermostat and seal
Ignition switch
Other things noted:
Fuel tank was drained, cleaned, and flushed.
Engine Compression:
#1: 165 #2: 165 #3: 162 #4: 173 #5: 165 #6: 175
This car is a really really nice driver, and also really fast...surprisingly fast. Can cruise at 85. If you want the footage then maybe I can find it.  The paint is original, but it looks like someone tried to make it look nice but failed with the buffer and they made some bad marks on the hood. There very tiny bubbles on the car that are noticeable up close. It is a 5 footer. The interior is pretty nice, the dash does have cracks, and the seats are original and crunchy from the horse hair. Everything works such as dome light, the warning signals for when the doors are open or when someone does not buckle their seat belts (or a bag of groceries) The fuel gauge does not work.
$6,300
88 IX, 74 02, 72 02tii
