rapandi
Hole next to the air filter housing - is it factory?
22 posts in this topic Last Reply
Hi,
Can someone confirm that the circled hole below is not factory. It looks like it was drilled by the PO and whilst I am doing the body work I want to plug it. I just want to make sure I am not missing anything here.
You can see it below next to the air filter body
Regards
Raj
My '72 has the hole and it looks like something was there at one time. My car had AC earlier in it's life and the whole system was removed. Could it have been a relay or something else for the AC system?
Tony
(edited)
Even my poor 2762757 (October 19, 1972) has it!
Just wait: someone on this forum is going to say something like, "Oh, yeah, that's where the strut enhancer mounts on all the Euro cars..."  And that's the beauty of the forum!
Edited by Conserv
Um.  My car is euro, and it looks like nothing was ever attached.
Now, a lot of Swiss, German, and French air flowed through it, so it is probably worth more than the US version. ;)
Scott
PS  As I like to say, "they are ALL euro"
(edited)
Scott
I WAS joking, Scott, trying -- I mean utterly failing -- to illustrate that someone on this big wide Web might actually know why those holes exist!  I plucked "Euro" and the non-sensical "strut enhancer" out of the air!
Best regards,
Edited by Conserv
It's securing the battery ground wire next to the 3 musketeers, as I named them, because I have no idea what they do. ; }
(edited)
Well, Nick, it's a little different because none of our round taillight cars is using that hole.  The square taillight cars got the neat "relay rack" and I believe most of them use the rack itself as the ground.  I can't quite "read" your photo, but my '76's is clearer -- at least to me -- as to how the ground attaches.  I have 4 Musketeers, because 3 can't always get the job done:  2 high beam relays, 1 horn relay (is that right?), and one fog light relay!
Best regards,
Edited by Conserv
Oh right. Raj's car is a 73.
I kinda liked referring to them as the Three Musketeers. Now you have burst my bubble! What's next? No Easter Bunny?
It may even look like my rack has been bent, causing the 4th space down toward the fender. I'm not home to look, and won't be for a while.
Maybe I'll ask Santa. He knows everything!
Oh, I know.  I was piling on in my feeble way.  I think on my car, that hole was put there by Alpina...it looks different...racier...
Scott
3 minutes ago, saaron said:
...I think on my car, that hole was put there by Alpina...it looks different...racier...
Scott
It looks it, Scott, and my '73's was drilled by Miller & Norburn -- it's a U.S. version, after all -- for brake cooling:  the small diameter, under the Bernoulli effect, dramatically increases the velocity of the air flow.... ?
Best regards,
Best regards,
Reduces weight, too.
And so you should. #4 is an Easter D'Aatagnan.
(edited)
Raj,
      my '74tii has the same layout as Nick:  3 Musketeers on the bracket ...... with the ground wire bolted to the bracket ...... and the bracket welded to the body.  NO holes through the body.
Cheers,
Carl
Edited by OriginalOwner
