clutch reassembly question
was wondering if anyone had any clever ideas or tricks/techniques about how to centre the clutch drive plate when re-assembling the clutch/gearbox. (i dont have a spare gearbox centre shaft lying around..)
best wishes chaps
ozgeorge
Well its not really smart, But Ive done three motors this way and have had no trouble.(Other than Jarry breaking his car last week)
I take a socket that fits in he pilot bearing hole. THen I take the extension and rap it with electrical tape till it fits snuggly in the clutch disk. I tighten down the pressure plate and remove the rig. I then check it by eye to see if its straight. If not Ill go back and do it again till it is right.
NOTE: This is only if you cannot find a cluch alignment tool at the local auto store. I had one, but in my usual fasion forgot to bring it with me on 2 of the ocassions, and the third was a non BMW motor.
Good luck
Andy Rattley
Clutch alignment tools are $5-$10 (Shucks/Kragen will probably get you the wrong one, call one of the 02 vendors)and are worth the money if youve ever misaligned the disk. Also, for lining up the trans to the engine I used a trick others have posted that worked like a dream. Get two long bolts of the same diameter as the ones that mate the trans & engine, cut off the heads and slot the end for a screwdriver blade. easy to do with a dremel or even a hacksaw. insert them into the block and use these as guides to line up the tranny. It will slip right on the first pass gauranteed, possibly saving you a lot of frustration lining up the input shaft. (Ive heard of people spending HOURS trying to line up the input shaft,,, ok, it was me. on another car though)there is very little room in the transmission tunnel to jocky the gearbox around and the bolts will act as guides.
The auto parts store didn't have one for 2002's in stock, so I found a piece of PVC pipe that was slightly larger than the openings and ground it down to fit tight. It worked much better than I expected. I've since added an input shaft to my tool box, so I tossed the pipe. 8-)
