(Pics) 40DCOEs with straight stacks and angled filters, stock booster
KFunk
I've been slowly trying to clean up my engine bay, and wasn't thrilled with fitment of IEs straight filters, and I accidentally damaged one by tightening the clamp too much. IEs bent stacks won't fit my Italian carbs. Someone posted a link before to some angled filters from Spruell Motorsports, but those are discontinued.
Eventually I found these, which are almost exactly the same size as IEs, but angled 15 degrees, and have a removable red pre filter that can add a little to diameter.  It's not a perfect fit in terms of looks, but better.  More angle would be better to get fronts to match rears, but 15 degrees is about the only option.  They did not include the rubber inner collars which are necessary for clamping to the stacks, so I reused mine from IE.  Someone needs to get a source for them.
https://www.denniskirk.com/uni/two-stage-pod-filter-w-angled-flange-2-1-4-in-i-d-x-4-in-l-up-4229ast.p305044.prd/305044.sku
Now time to clean up some of the wires with friction tape and clean up some of the paint.
Edited by KFunk
Bring a Welder
But how does it look with the filter on the back carb? Probably a little smashed and crammed on? It looks like they could help just a bit, but really I'd like the full curved ones like IE has for the Spanish Webers.  I'm not sure how the length and end width compare to my stacks, which admittedly I have not measured.
Bring a Welder
Oh, and I should mention I have a warneford manifold, which is a good bit longer than some of the short manifolds.  I think it's supposed to be nice for bottom end torque, but does suck for filter clearance.
Bring a Welder
Ummmm...15 degree UNI filters?
...been running mine almost 3 years; they are great.
Looking back, I bought mine from DennisKirk, also.  I bought the longer version, but don't use the red, pre-filter.   These are the early, Alpina A2 Solex 40DDHs.  The stacks on this set up are cast aluminum, not terribly long, they have a venturi profile but don't have the tulip lip; so the UNI filters attach without the donut.  Pretty slick, really.
Ed Z
Edited by zinz
'69 Granada... long, long ago
'71 Manila..such a great car
'67 Granada 2000CS...way cool
