Need to clean my shorts after seeing how much Maximilian wanted for 1 rear shock and spring.  Over 300. Per. I dont. believe they can't be found somewhere else.  So I'm putting the call out!  Any idea's would be great!
I have seen some in Germany, but won't ship to States. Bummer!  Sway bars would be nice too, but being pre 66 complicates  things. Those little difference add up(simple) NOT!!  Thanks 02faq?
Brandon, contact KONI USA and see if they still make shocks for a BMW 1800, they used to. BilStein shocks are better, and may not be available anymore. New rear springs will make the car much nicer , They had a tendency to sag after a couple years.   The front sway bar is the same as a BMW 2002, and the rear sway bar is the same as an E nine coupe.  I got my sway bars from Carl Nelson, who is great to deal with and has a Tisa.You can still get both, and sometimes find the  sway bars used.
Sincerely, Peter
The First thing is to have an untroubled mind. The Second thing is to know your purpose. Illigitimati Non Carborundum
