2 hours ago, Healey3000 said:
I suppose one could fill the pump and lines with liquid and run input to output
Must add to the scheme a method to dissipate the heat from the liquid.  The work input to the pump has to go somewhere and it will go into heating the liquid.
The pump usually pumps a cool liquid (relatively cool anyway) and the components may not hold up with hot liquid.
A small power steering oil cooler would work fine.
  • Haha 1
George S Patton
This thing is wandering into Rube- Goldberg territory now! Are we better off with just semi sequential injection at this point?
Still, a fun mental exercise.
Hi,
A question for those who have a diaphragm from the original or replacement pumps (the kind that can be taken apart to replace the diaphragm) - is the metal disk that forms the central part of the diaphragm ferromagnetic? Pictures of this would be useful too, if you have them.
Thanks.
  • 3 weeks later...
Well, sensor installed and passes bench test! Collar with small spring trick seems like it'll work great! Apparently the sensor has an internal pull-up, FYI, no external resistor needed! Now to just get the engine all back together and in the car to really test!
Looks great!!
Hi,
What's the temp rating on the sensor? Why is a spring and collar required. Sorry, I'm not been keeping up with the various designs.
Thanks.
Will it survive the temperature? I've read it can be around 200 C.
A question - when the lobe is at maximum (presumably as shown in your pic.), how much of the sensor sticks out (dimension)?
Thanks
