Testing rebuilt starter just installed on rebuilt engine.  Solenoid was replaced on starter when it was rebuilt.  Turned right over but would not turn off when key was released.  Tried three times with same result.  Removed starter and did a bench test.  Worked perfectly.  We replaced starter on engine and used remote switch (same as in bench test).  Starter just kept cranking even after switch was released.  Can't figure it out.
Sounds like the Bendix drive isn't disengaging from the ring gear.  If it doesn't, then the solenoid's contacts will not separate, thus continuing to feed current to the motor.  With no ring gear to engage when bench tested, it works just fine.
You're gonna have to check your flywheel ring gear for extreme wear, and also the Bendix drive for misalighment or some other problem.  If you didn't have this problem with your old starter, I'd suspect the rebuilt one...
