Need advice on rad size and thermo fan
Driv3r
I'm having a nightmare trying to source a suitable solution for my turbo build. I need to buy either off the shelf or custom rad that could fit with thermo fan inside the engine bay as I have already used the nose for oil and inter cooler.
Has anyone installed thermo fan on a FMI turbo 02? Keeping the stock fan is not an option. Turbo 02s, any suggestion?
Cheers
No one that I know of has a puller fan on their turbo setup, they all run pusher fans. There really isn't enough room in a 2002 engine bay in stock trim for a radiator and a puller fan.
-Nathan
Yes but where do they install the pusher fan? There's no space in front of the radiator, it's taken by intercooler and oil cooler. I can fit two 7" puller fans on each lower side of the water pump pulley but not sure if that's recommended. They pull 30 amps combined.
Edited by Driv3r
Do you know what CFM they will pull?  Puller fans are always more efficient but you might struggle since you will miss so much area of the radiator.
Can you modify the nose to allow the radiator to be mounted further forward?
rtheriaque wrote:
Probably a subject more for curbside argument than any real benefit because pulling 1200cfm of heated air does not move as much air mass as pushing a bit less cfm of cold air.
1700 cfm combined. Even if I cut the front, there is still no space. Intercooler and oil cooler are already there.
how is a puller fan pulling heated air from the front nose of the car? Isn't puller fan inside between the pulley and rad, pulling the cold air from outside?
37 minutes ago, mlytle said:
Move the oil and inter coolers. .....
To where? I could probably find a place for the oil cooler but intercooler is custom FM.
Edited by Driv3r
How does one pull air out the front of the car?  A puller fan pulls air thru the radiator, putting a puller fan in front of the radiator and blowing the air out the front doesn't make sense.
Should of thought of that while planning the project.
Like others said, move the intercooler and oil cooler. This is one of the turbos I've seen done. It all doesn't have to be stacked in front of the radiator.
Edited by roadhog0
-Nathan
As a matter of fact, having the intercooler close to the radiator actually decreases its efficiency and increases its overall heatsink suckiness. Trust me, that's why I went to twin intercoolers. Realistically it should be below the radiator and exposed to as much ambient air as possible.
My apologies if I wasn't clear. The puller fan that I was talking about sits behind the radiator and in front of the water pump pulley, sucking the air through the radiator.
I've purchased this as half finished project. The PO had the intercooler custom made and installed.
The stock 2002 Turbo radiator is about 5" wider than the stock 2002/ti/tii radiator.  It leaves enough room for the engine driven fan.  You could always try the 2 smaller fans mounted either side of the water pump shaft.  There is no reason they should not work just fine (30 amps is a lot and you will probably need to up your charging system to compensate).  You can always have a custom radiator built,  there are many companies that build them, you just need to figure out how much room you have, how you are going to mount it then carefully measure (3-4 times just to make sure) draw a diagram and send it off to one of them and see what they say.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
