What piston do I have here?
I don't have them out, but look much bigger than the normal grand piano style I've had before......I'm thinking closer to 10.5:1 or higher?
Thanks
02MM
9.0:1's should have a 4.5mm dome. The fact that they are 89.97mm would indicate they're probably Mahle's since BMW didn't make them any bigger than 89.47. Those would be good set-up for a tii running in IT since they're stock comp, and the max allowable oversize.
Matt
These pistons...you're saying 9.0:1CR, a Schrick 292 (real, not regrind) and Weber 40DCOEs.....Bosch blue coil, mechanical advance dizzy, and I'll probably get an electronic ignition set up....
What kind of performance and reliability should I see with this set-up?
TIA
02MM
